Hello everyone,
I have yet another problem.
Initially, the motor was shaking while in neutral and in gear.
First checked the spark plugs and number one and two were fouled.
Changed all spark plugs.
seemed a little better.
Checked the engine with YDS and found 2 codes and fixed the 2 codes.
Now the idle came down a bit and it was running around about 850 +/-.
I believe the idle speed is correct but what would cause the motor to shake kind of hard.
I have read a lot on the forums about this issue and I did clean number 1 and 2 injectors.
This motor is a 2003 F115TXRB with only 83 hours on it.
Any suggestions or help would be greatly appreciated.
BTW did oil and filter change and all fuel filters were changed as well.
Thank you in advance.
