I Just bought a 1992 40MJHQ jet. While running it to flush and fogg i noticed water leaking out around cylinder head gasket. Is there enough clearance to pull the bottom 2 head bolts out without removing the powerhead? and is this a common problem on these 3 cylinder motors? Also is possible to remove the cylinder head without pulling the head cover and gasket?
