2011 f40la (efi) outboard bogging down
  • 2011 f40la (efi) outboard bogging down
    i have a 2011 f40la outboard was running fine then one day just wouldnt get on step anymore only turns about 4000 then after awhile runs like a champ. when its bogging down if i hit the trim switch up or down it bogs down. and when i first start it gotta turn the key 2-3 times before it will start. im thinking its the high pressure fuel pump. any help would be greatly appreciated.
    Any one have any info ? At a lost. Had dealer run the computer. Nothing wrong with it. But still boggin down.
      need to be testing while problem shows up
      Spark, timing, and fuel pressures to see what is happening
        Has this engine had the high pressure pump replaced under warranty? there was a tech exchange on them some time ago(for engines that fell within a serial no range) - quiz your dealer.
