tach
  • tach
    Will any Tach work on my f60
    Since you are not telling us whether 'your' F60 is a 2002 or a 2020
    the only thing that can safely be stated
    is that a 6Y5 or 6Y7 tach 'can be made to work' on it
      I suspect that a mechanical drive tachometer will not work.
        and some of those tachs that you wrap the signal wire around a plug wire may have a problem with all of the signals induced by the other plug wires it picks up
          opps sorry guy's it's 2007
            So you can use a Yamaha 6Y5, 6Y7,
            or any non-Yamaha 'conventional' tach that provides for a "12 pole' input
            those would use the green wire off the keyswitch/703 control
            or Command Link 6Y8 round (or square, if you can find one)
            which would connect via the engine harness CL plug
              thank you.
