What is this? Vacuum port/valve by ECU 2015 F115
  • What is this? Vacuum port/valve by ECU 2015 F115
    What is it? Hose missing? It pulls a vacuum when the OB is running. It is peeking out from behind the gray hose.
      That's the "ISC" valve - Idle Speed Control
      Its a way for the ECM to get air into the cylinders
      since it doesn't have control over the throttle
        Thank you!
