I have a 05 F150 with a speed and a tach multifunction gauge, the one plug in the back of the tach is for oil and trim... But what is the other plug for ?
yamaha multifunction gauge Question
Originally posted by darrellsimons View PostI have a 05 F150 with a speed and a tach multifunction gauge, the one plug in the back of the tach is for oil and trim... But what is the other plug for ?05 F150 TLRD
06 23' UltaCat
I just purchased the boat in November and the Tach works fine other then the trim indicator on it stayed pegged out. After doing some trouble shooting I found it was never hooked up, so I purchaced a trim/ oil cable pluged it in an every thing works fine now on the tach but I still have the One Nylon plug not being used and just was trying to figure out What if any should be pluged into it ??05 F150 TLRD
06 23' UltaCat
*** ******************Last edited by darrellsimons; 01-24-2015, 10:59 AM.05 F150 TLRD
06 23' UltaCat
Let's go all the way back to your original question.
"I have a 05 F150 with a speed and a tach multifunction gauge, the one plug in the back of the tach is for oil and trim... But what is the other plug for ?"
The other nylon plug on your tachometer is used to receive information from the motor so that the tachometer can provide full functionality. With out the other plug being used your tachometer cannot display certain information that the motor provides.
Originally posted by 99yam40 View PostSeems that if the tach has a different number of connectors than the motor does then you will need an adapter at one end or the other , depending on the cable you have installed
You nailed it, after your replie I did some more research. It seems that what I have is a Pre 2004 Tach on a 2005 motor. But not a problem, with the adapter
( 6Y5-85335-00-00 ) you can use a pre 04 tach on a 05 and up motor , or a newer tach on a older motor.
I guess the previous never felt he needed any of the trim or alarm hooked up.
Thanks05 F150 TLRD
06 23' UltaCat
