Im looking to upgrade with a 2000 Yamaha 100-HP four stroke outboard. Does this have a carburetor? Anyone have any comments or experience on this model motor... Good? Bad? Problematic?
Buying an F100hp
A carburetor? How about four of the bastards?
Carburetors can and will be problematic.
If the fuel is kept clean and the motor is used frequently it can be a good motor. Let it sit not being used for long periods of time, or use degraded fuel, and it can be the motor from hell.
Look at the prices of a carburetor should you ever need one. Or two. Or three.
You might want to consider upgrading to an electronic fuel injected F115.
As you stated, if you keep the fuel stabilized, etc, I'd rather have carbs in a NY minute.
Much more user friendly should you have issues.
You don't have to send out injectors, not nearly as many filters, buried VST's and filters. HP pumps, LP pumps, etc. Put a butterfly choke on the carb, even better!
Put the dirty carb on a bench, clean two jets (usually), re-install...Scott
Use fresh fuel or a fuel stabilizer (i donīt use fuel stabilizer as I use portable tanks and the gas don't sit for too long), drain carbs if you'll be with out using it for a few weeks or more, no ethanol here..., and very important use a pre fuel filter with water separator IMO
I have a spare set of carbs for my motor but fortunately I donīt need them so far...
Originally posted by Marc Kruse View PostCheck the rectifier/ regulator they've been known to over heat an burn up your ECU unit
If you find one at good shape and you take good care of it I guess you'll not be desapointed...
Off couse if when I bought mine if I could choose an EFI that would be the choise but were not available at the time...
Originally posted by almetelo View PostCarbs on this model is known as could be problematic but on my F100 I have no complains so far...
Be sure you keep all current connections tight.
