Yamaha needle bearings
  • Yamaha needle bearings
    Hello I was wondering if anyone new of a good grease to use on wrist pin needle bearings.I want to install new wrist pins and needle bearings on a new crankshaft and I want to use the right lubricants.The needle bearings are not caged they are loose,I don't have the special Yamaha tool for this so I figure I could use a light grease on the wrist pins and roll the needle bearings on the pin then insert them into the rod.Looking for advise.
    vasoline.
    also known as boy butter.
    vasoline will work.
