F225 Oil Change
    Mine for the F200/F225 shows 19 ft-lb [sic]. Must be a rounding issue. The other values (which are correctly states as N-m and kgf-m) are the same as what your F150 manual shows.
    You gotta love Yamaha data. Inconsistent, inaccurate, with lots of stuff simply left out. I guess their thinking is that if they don't add data to their manuals they can't get it wrong. Worse yet, when they know that it is wrong they never take action to correct it. Ever heard of a revision to a Yamaha outboard motor manual? I haven't.
    Oh, is it a bolt or a plug?
      The motorcycle world is the same.
      In the Yamaha FSM,(both the 04-06 and 07-09 FZ6 bikes) for checking valves / servicing, its clearly noted to crank (by hand) the engine BACKWARDS (CC on the right side) when rotating the crank to check the next cylinder.. This is OPPOSITE normal rotation...
      No updates/ corrections, etc... Jeez..
