Motor overheating at midrange to full throttle.Removed lower unit check w/p
impeller looked newer,housing looked ok.Replaced w/p & housing & thermostat.Checked popit clean working ok.Tell tale weak.Back flushed motor with lower unit off.Installed lower unit flushed again still weak tell tale.Test run overheating 180 to 190 with temp gun.Boat bottom clean no restrictions in front of lower unit......
