Remote T/T switch
  • Remote T/T switch
    First thing, I have a manual but I'm in another state and won't be back for 5 more months.
    I need to get info on how to wire a remote T/T switch on my F90TLR. Either a reference to an article or send me a copy of manual, if possible.
    Any suggestions would help.
    What type of control box?
      Control box: Yama 704 Remote Control.
        under the 704 box is a harness with 3 wires.
        lt green,lt blue and red,.
        red is switch power,lt green is down, lt blue is up.
          I found the wire.
          I want to verify that the connection is correct before i go charging off and start running wires.
          At the console, if the red wire is power should I be able to touch the blue-to-red for up and green-to-red for down. I wouldn't think this would cause any bad issues but sure would hate to smoke something.
          Also, any suggestions on a reasonable T/T switch to mount up front. This is severe environment (salt+humidity) in southern FLA.
            As a test you can jumper the red wire to the blue wire in which case the motor will trim up. Red to green and it will trim down.
            Here is a switch from Yamaha that will make the job plug and play.
            2014 Yamaha MRP Catalog
            688-82563-10-00 Yamaha Remote Power Trim and Tilt Switch
