2000' HPDI's
  • 2000' HPDI's
    I have a pair of 2000 Yamaha's HPDI's. I'm changing both water separators and flow fuel sensors that are in line after separators. Can someone help me with correct part numbers, I've checked on-line but getting two different numbers...6Y5-85752-01-00 and 6Y5-85752-02-00...Is one for dual motor applications? and if you can send info where i can buy them also....Thank you.
    J.R.
    2014 Yamaha MRP Catalog
    6Y5-85752-02-00 YAMAHA SENDER UNIT ASSY, FU
      Thanks for your help
        I bought a used flow scan for one of my year 2000 150's. Only to find out the harness was corroded. Pin out the harness with a jumper and multimeter, its only three wires per engine.
        I was able to purchase new connectors and reterminate the harness and flowscan transducer from a tip on here.
        Google Eastern Beaver motorcycle electrical connectors in Japan
        Best regards,
