I'm not sure about the shaft propeller parts of 225Vmax
I have YAMAHA Vmax [225GETO 66K L 304504], I want to replacement the shaft propeller but I'm not sure about the parts No. of shaft propeller between 69J-45611-00-00 and 61A-45611-02-00 or other.
goes back to the jinglish .
its a translation issue.
here in the states its a propeller shaft.
its a simple replacement.
wont require any reshimming.
will need prop shaft seals and the carrier oring.
will also need shift shaft seal and carrier oring.
may as well do the drive shaft seals and carrier oring.
nice thing about mechanical things is they work the same regaurdless of language.
In parts catalogs it is "REF No.48", I'm not sure because in model year 2003 PART No. as show 69J-45611-00-00 but in model year 2002 as show 61A-45611-02-00 , Can anyone confirm?
