Problem resolved.. I put the new starter back on and did some research on wiring and it turns out the 12v wire leaving the starter wasn’t getting a connection. The old starter was definitely going out though. Once I got the wire connection fixed on the new starter she fired right up.. I appreciate all of the responses on this thread, I tried each and every suggestion which led me to finding the issue.. looking forward to helping you guys out when I can with your issues
Starter install gone wrong.. 07 225 hpdi
good to hear,
that makes sense, there was a bad connection.
was it due to something getting in the way of the lug making contact on the bolt/nut?
Just for curiosity, might wanna pull the OEM starter apart and check brushes, etc...
As expensive as they are, if it's a simple worn out brush, etc, might be worth fixing/saving..
Aftermarket parts as such, (IME), don't tend to hold up as well as expensive OEM ones..
.Scott
Originally posted by TownsendsFJR1300 View PostJust for curiosity, might wanna pull the OEM starter apart and check brushes, etc...
ÂÂÂÂÂÂ
