Starter install gone wrong.. 07 225 hpdi
    Problem resolved.. I put the new starter back on and did some research on wiring and it turns out the 12v wire leaving the starter wasn’t getting a connection. The old starter was definitely going out though. Once I got the wire connection fixed on the new starter she fired right up.. I appreciate all of the responses on this thread, I tried each and every suggestion which led me to finding the issue.. looking forward to helping you guys out when I can with your issues
      good to hear,
      that makes sense, there was a bad connection.
      was it due to something getting in the way of the lug making contact on the bolt/nut?
        good to hear,
        Yea, the lug/washer wasn’t on correctly. I get like an idiot once I figured it out.. it happens though.
        • #19
          Just for curiosity, might wanna pull the OEM starter apart and check brushes, etc...
          As expensive as they are, if it's a simple worn out brush, etc, might be worth fixing/saving..
          Aftermarket parts as such, (IME), don't tend to hold up as well as expensive OEM ones..
          • #20
            true, there are starter and alternators shops that might look at it for you if you do not want to do it yourself.
