new water pump still no water
  • new water pump still no water
    I have a 1999 200 hp yam I installed a new impeller and howsing new thermastats water is not reaching the thermostats it is coming out of the telltale but not very good aNY body knows why ?
    my guess would be a missing or stuck open pressure control valve.
      Pulled it out and checkEd it all ready had a guy tell me that it was the gromit under the power head or a gasket I really don't want to pull this motor apart anything else I can try
        barring a hole corroded in the water jacket or tube AND assuming the water pump was installed correctly there are basically two things that can dump water pressure on a 2.6L v8.
        one is the pressure control valve is defective,missing or not sealing on the grommet and two is the two small restrictors under the powerhead are missing/melted away.
        I have seen the water crossover passage under the powerhead corrode a hole through.
        this will be noted by water pouring out around the tiller area just under the powerhead when running.
          new water pump - still no water
          I have the same issue on a 2002 100hp yamaha. I must have taken it apart 300 times. I finaly put the old impeller back in. Now I have water - go figure..... The only thing that I can figure is that the new impeller is so tight that it makes the metal can inside the housing spin with it. I plan on ordering a new housing soon.
