Hello group. iam looking for a 2001 Yamaha f225 txra crankcase. pin hole in the bottom of the water jacket on mine,
yamaha f225 txra crank case
Originally posted by blue wave boy View Postthink a weld would hold up under the heat?
.Scott
Just an FYI, I had an old Merc(bout a 90 HP) with issues. I found a hole rotted thru the water jacket in the head, DIRECT TO THE COMBUSTION CHAMBER.(much more heat than a water jacket alone).
That engine did not have a removable head as I re-call. Cleaned/ then trimmed up maybe 1/2" piece of aluminum and had it TIG welded in.. Worked great, got another hull and sold it..Scott
