Originally posted by 99yam40
View Post
Looks just like a typical 4 stroke crank.You had me worried though.lol..
I should have added the pic of the oil sump pan...
A sludged mess to say the least,the oil strainer was all caked up to.
You would think if that was the prob that it would have an equal effect over all & not just one bearing.
The 1st thing I did was look through the oil passage after removeing the crank & could see through it...I don't quite get it???
There was no bearing pieces,Its a "babitted" rod like on the older Chevrolets where the bearings moulded into the rod.I never understood that term is that what it means?It don't have inserts like the main journals do.Maybe it don't have them at all & its just a machined rod.IDK? Youd think it would be more than meets the eye there?
Thanks!
Marty
