I have a 2005 Carolina Skiff with a F60TLRD.
My tilt trim relay blows the down position once in a while when either the motor is running or when the motor is cranking to start. The tilt up position works fine all the time.
So to briefly explain what happens. Bought the boat used from an auction and found that the trim up works but the trim down doesn't. Of course, I believed it was the relay so I bought it and installed it and everything worked like a charm. I can tilt up and down on dry land all you want. Put the boat on the water and started it, trimmed down everything went fine. Drove it around for a little, trimmed up everything when fine but when I trimmed down it didn't work anymore.
Bough a new relay. Maybe the first one was crappy. Installed the second relay it works like a charm on dry land. Put it in the water. Used it for half a day trimming up and down. One time when I went to crank the engine and when I went to lower the motor... nothing. I also noticed that when I cranked my Humminbird turned off I thought "weird" because the Humminbird is connected directly to the battery. I connected it that way so I can keep my fish finder on when I'm anchored and motor is off. Maybe there is a surge coming from the starter / alternator during cranking.
So question is. Why is it only blowing the tilt down part of the relay? Why during cranking? and why not all the time? What should I check. I can't see any improperly grounded or exposed wires shorting anywhere. Something in the trim tilt motor? Any part of the engine I can check? Can there be something with the helm? Also should the Humminbird turn off during engine cranking?
