I have a new 2019 115 and my forward and reverse shifter clip on the engine control arms keeps falling out leaving me only reverse. This has happenened 3 times already. What is causing this (vibration?)? I am about to just put in a cotter pin because ...this is a real pain happening out on the water. Thank goodness I have a great *****ing motor to get me back to my dock. Any info why this is happening would be much appreciated. The motor is still under warranty but my dealer is really far away.
2019 Yamaha 115 Shifter Issue
Originally posted by robert graham View PostIf there's a hole in that pin to put a cotter pin in then maybe a good solution....a washer under cotter pin might be good also....just curious, but what is supposed to hold this pin in place?...
Looks like the cables right there in the pic are likely pushing the clip off..
Simply shifting it(while running/on muffs) will show what's pushing the clip off..
Or put a SS cotter pin in it and be done with it..
**BTW, I kinda doubt Yamaha would want battery cables laying directly above a moving part as over time, there will be issues/dead short (poor rigging). Might want to move those cables where nothings rubbing on them.
Capture.JPGLast edited by TownsendsFJR1300; 05-18-2020, 06:24 PM.Scott
That is a great point. Once the shifter is hooked-up it is acutally away from the battery cables but I was putting in the clip with the open side facing those cables. Therefore during the shifting it probably was slightly touching the cables pushing the clip out. I think by reversing the clip with the rounded portion of the clip facing the cables if there is contact the cables will actually be keeping the clip in place. I bet that's the answer !!!!!! Thanks Guys
Â
