Originally posted by 99yam40
View Post
Here is what I think that we know.
1. The trim/tilt motor works fine when powered directly. Positive to the blue lead and negative to the green lead and vice versa.
2. Two relays; his and the one that he got ahold of.
3. Both relays work on the other motor. Both relays don't work on his motor.
"So, I got ahold of someone with the same motor and swapped out relays between motors. The relays that didn't work on my motor worked just fine on the other one."
"The relay on the motor right now has been tested on another outboard and it worked fine. When installed back on mine its back to the clicking."
