my yamaha saltwater series 2000 200hp stalls when put into gear slow.new needles in carbs,spark plugs,fuel pumps,filters,fuel tank and lines
yamaha 200 saltwater series stalls when put into gear slow
Shifting slowly... Don't do that. Shift quickly.
Although, I'm still confused by this:
Originally posted by xandar11 View Postdo you mean forward control unitLast edited by DennisG01; 12-11-2014, 07:21 PM.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by xandar11 View Postsorry i am only new to this i do need answers for my motor
And, I think what the other guys were getting at (please correct me if I'm wrong) is that the information you provided was confusing. Sometimes, people will post something like this for no reason. Sort of like "spam" email.Last edited by DennisG01; 12-15-2014, 06:42 PM.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
I see the correction for NEEDLES for the carb (from your first post). What needles are you referring to? The FLOAT NEEDLE??
You going to have to go into some detail, SPECIFICALLY what you have done.
If you can upload a video with audio would be a big help..
And PLEASE, THE MODEL # to the engine, should be a 4 letter code..Scott
Scott, I was thinking it might be as simple as shifting too slow and engaging the shift cutoff switch too long (or possibly the switch is hanging up/flaky)? I know the main purpose of this switch is for coming out of gear, but it still cuts spark when going into gear, right? Or am I mistaken on that?2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by DennisG01 View PostScott, I was thinking it might be as simple as shifting too slow and engaging the shift cutoff switch too long (or possibly the switch is hanging up/flaky)? I know the main purpose of this switch is for coming out of gear, but it still cuts spark when going into gear, right? Or am I mistaken on that?
It could be as you noted Dennis. The OP needs to post some legible/understandable information (or he's a *****)..Scott
salt water series
the engine no=feto x .when you put it in slow from 1000rpm to 1400rpm try to crawl it will stall.the motor has been serviced by a yamaha dealer and the part that your talking about is it in the forward con***** or on the engine the engine will run on idle and rev up in nuetral with the fast idle but soon as you put it in gear it stalls.thanks for any help needed.
