I have twin Yamaha 225 four strokes 2005 models and have two control stations. top and bottom.
For this I have two control boxes and two shift boxes. one set for stb and one set for port.
I am in the process of replacing all my cables for this system as they were worn and needed to be replaced.
Took the boat out yesterday and on the top station was getting a lot of alarms which I asume were the shift alarms, so assumed something was set up wrong on the top station, I found two cables that were crossed over port and stb, fixed those but suspect I have other cables that were set up wrong as I am still getting alarms and now both motors have stalled and will turn over but will not start.
Can you send me a diagram of where the cables fo rthe top system and the bottom system go (one side of the box is shift and one side is throttle four cables enter each control box, top and bottom... I am thinking I put the cables in wrong..
Why are the motors not turning on or is the part of the shift system and will resolve itself when I have the cables set up correctly or is there a reset I need to do?
I live in Panama and believe my boat is the only boat with this system and the local Yamaha dealer has no idea on how to set this up. This was my previous experience three years ago.
So appreciate your help on this.
thanks
thanks
