I own a 2005 200HPDI mounted to a 1992 Grady 226.
From day one, when in the trailering position, the tilt rod retracts fine, but the trim rods take 2-3 full minutes to retract, and there is a high pitched gurgling sound like air.
At the 10 hour check, the dealer confirmed fluid level was full.
At the 100 hour check, I expressed my concerns, and he reportedly bled and checked the system.
No change, so I just got off the phone with Yamaha. After soem research, was told by tech that some model HPDI's and larger 4 strokes use a different trim motor which will retract as I have described due to no weight on them.
Here is my concern. The boat is kept in a slip, and the trim rods need to be retracted to keep growth from getting on them. In the manual, it tells to retract them if boat is stored in the water.
Is it reasonable for me to hold the trim button down a full 2-3 minutes everytime I put the boat away?
Might Yamaha replace the motor with one which will operate, in my opinion, correctly for my uses?
I have owned 4 other Yamaha motors (regular 2 stroke), and all have operated in the manner I see as correct.
Thanks,
FISHNFF
Thanks,
FISHNFF
