Yamaha S150TXRW no 12V power at Red pin of 10 pin harness
Anyone ever replace Yamaha main harness on the motor side? I have no voltage at the RED pin of the 10 pin connector
Where does the harness get the 12V from at teh motor?
There was another thread recently, someone with a similar question,
Boscoe posted the wiring diagram -
you might see if you can find that.
Alternatively, look at the wiring under the starter motor
on the red wires, a couple of rubber capsule shaped objects
pull those apart and check the fuses inside
