I have a Yamaha F100 outboard, it doesn't get used much.
The problem started about 10 hrs run time ago, it would be a little rough for 10 mins around mid power then clear and work finn.
Now it starts ok and ticks over ok, as soon as you throttle up even without a load it caughs and runs rough, doesn't reach full revs.
Ive replaced the spark plugs, 2 were quiet black, still have the problem.
I checked the spark and on all HT leads it was a weak spark, tried another lead of a car - still weak.
I pulled the Ht leads off when it was ticking over, each one made it run rougher so i presume they are all working to some degree.
All the wiring looks ok, any ideas please would be greatly appreciated.
