F225 goes very high rpm on startup
  • F225 goes very high rpm on startup
    My outboard f225 4stroke 2007 running 1200 hrs now and never had a problem
    Last trip the rpm went high to maximum rpm at idle that I had to shut it down
    I tried to start the engine today .. Same thing happened .. It goes crazy high rpm right after it starts .. With loud back fire
    What is wrong?
    have you even looked for any problems before asking us who cannot see your motor or controls?
      I took a look on the cables inside the engine but did not notice anything
          i had the same issue. it had a crack in the intake manifold its plastic.you can test it by starting the engine and spraying carb cleaner and the RPM will lower. i took mine off and cleaned it up and put some 5200 on it and been runing for years .
