Yamaha 15hp outboard 2012 charger
  • Yamaha 15hp outboard 2012 charger
    Gday,
    I've recently brought a 2nd hand motor that has a charger set up already atttached, am I ok to run that straight to the deep cycle battery I use to run my electric motor ???
    Not sure if the pics help??
      You can certainly connect the motor to the battery. The issue will be that the output of the motor is so small and the demand of a *****ing motor is so great that for practical purposes not much will be done.
        Thanks mate!
        Will connect it and see how much charge I do get out of it.
          you will get roughly 6 amps at or near WOT. about 1-2 amps at lower speeds.
