Prop shaft removal
  • Prop shaft removal
    Trying to remove the prop shaft on a 250, can’t get the bearing to budge. Using an impact wrench and heated.
    what 250 are you talking about?
    hard to look up part diagrams with no info
      2007 not sure the model.
        did you pull the shift shaft?
        are you using a slide hammer screwed onto the prop shaft and trying to pull the shaft and carrier?
