Doing some preventative maintenance on an engine I got about 2 seasons ago. Getting into the carbs for inspections and cleaning and noticed that the upper carb was not the same as the other two.
Engine is 1993 200TXRR and found the bottom two were 6R401 and the top is a 6G603. According to the manual it only lists the 6R401.
Before I go down the path of changing the carb to spec, can anyone give me a valid reason why it would have been changed out?
Engine seemed to idle a little rough last year hence the thought of cleaning, rebuilding and then tuning the carbs.
Looking for some feedback.
