Protecting gas pump?
  • Protecting gas pump?
    Hi there!
    I am using the Yamaha F15 AMHS year 2004 outboard in my sail boat.
    During prolonged periods of mooring I use to drain the gasoline from the carburetor but the gas pump will still be full of gasoline.
    My question: Should I live it as is or should I manage to drain it too?
    Thank you
    Probably sufficient to use a heavy dosage of the Stabil Marine in your fuel system all the time and drain the carb....
