I have a problem with F6C outboard and I would really appreciate help. I had it for a little more than two years and was servicing it regularily. It worked fine and without the problem until few days ago. When I was starting the engine last time, it seemed to have started normally but after approx. 10 sec it stopped running. I tried to start it several times again, but without success. I removed the cover and noticed that, there is a leakage. I have market in a red circle the point from which the petrol is leaking. (please kindly see the photo). In addition to that, I noticed that when I try to switch the handle from idle to reverse sometimes it is possible to switch it as usual and sometimes it isn't possible to switch. It gets stuck half a way then I need to put it back to idle. I have also noticed that when I incline the engine, sometimes it helps and after that for some time it is possible to switch to reverse.
Thanks for your help in advance!
Boris
Boris
