Hello all!
We're taken ownership of a supposedly "lightly used" Yamaha outboard and are trying to get it running. It cranks strong but does not start. After some research it seems the fuel pump doesn't click on when you turn the key on. Further research and reading countless forum posts leads me to believe that it's probably something electrical rather than the high pressure pump itself. I've taken the fuse panel out and cleaned it after I realized how BADLY corroded it was (we live in Hawaii and the outboard was on a boat in a slip and then sat for a while). The fuses were really corroded so I replaced them. I bench tested the relays as per the manual (connected to a battery and Ohm meter) and neither show continuity so I'm thinking they are probably both bad. One of them makes a weird continual click/pop noise when connected to power (the other doesn't make any noise).
I get the feeling that the ECU isn't talking to the motor or tach/gauge. Just trying to start out with the simplest thing first. We live in Hawaii and it can take quite a bit of time and $$ to get parts and I'd really like to avoid just throwing money at the motor on things that may not be broken.
So my question are as follows:
Boats.net shows the part I need being 63P-82170-00-00 (https://www.boats.net/product/yamaha...SABEgIJU_D_BwE)
I found this one on eBay (part # 68F-82170-01-00) - seems to be for older model outboards (https://www.ebay.com/itm/2002-Yamaha...kAAOSwXedcJ5ca)
I'm reluctant to spend a bunch on new parts if I don't even know if this is the real issue, or just the start of a series of bigger issues. We're starting to feel like we had a "fast one" pulled on us by buying this outboard. Anyway, we would greatly appreciate any advice or suggestions for troubleshooting things.
Thanks!
- It's hard to get parts here on the Big Island without waiting for a week+ and with this current pandemic we're supposed to stay indoors. That said, is there a compatible automotive relay that might work that we can get at O'Reilly or Napa?
- Would it make more sense to find a lightly used fuse panel on eBay (that already has all the fuses and relays intact) or buy a couple new relays? Just buying two new relays is about the same price as getting a whole new-used fuse panel and having an extra panel would give us extra fuses and options to switch things out and trouble-shoot things.
- The last question is then, would any later model Yamaha fuse panel work or do I need to get the exact part number that boats.net shows? There aren't many options for my exact outboard on eBay.
Thanks!
