Float chamber gasket holder
  • Float chamber gasket holder
    Hi!
    What is the sealant/"glue" used to fixe/hold the gaskets on the cabs float chamber?
    Loctite 518???
    any other that do the job and if cheaper is wellcome.
    Thanks!
    vasoline.
    do NOT use any sealants.
      Thanks Rodbolt.
      Opened the carbs I got as spairs for a clean and removed the float chamber gasket
      What I found looks like a red sealant to hold the rubber gasket in place
      When reassembled the carbs the float chamber gaskets "were short" and had to stretch it a little to fit on the float chamber again.
      Vasoline is very usefull
