Trim cam sensor adjustment
    I may be an idiot . I may not have have reconnected the sensor wire this morning when I was rotating the cam . I'll bring a buddy by to be my right shoulder tomorrow and try this again !
      I would not think the top bar should not be flashing.
      might be that the wiring to the gauge is not making good contact in the connectors.
      as someone said already, unplug the sender and short the wires to the gauge,
      if still no gauge movement try shorting them at the gauge itself to see if that moves it
      bad connector, wire, or gauge.
      test and see
      Just noticed I had one too many not's in my post, remove the second one to make it correct.
      I would think the flashing would be because it is not connected
        Jumped across cam sensor connector doesn't change anything . Going to stop until my shoulder is usable
        • #19
          Is this the same F150 that swallowed a balancer a few years back and survived? If so, you are getting pretty good at removing that powerhead. Get well with the shoulder!
