In the process of shimming back my lower unit after disassembly. Wound up replacing the pinion gear. Have it all together and used the shins that I took out. I’m getting .057in (reverse gear) and .037in (fwd gear) backlash. Out of specs in both directions according the manual. The reverse gear solution, according the manual, is to remove shims. Right now I have two .3mm shims installed. According the manual calculations I need to remove .9mm of shim material. I do not have that material to remove. As it turns out, I’m needing to increase shim by .85mm for the fwd gear.
Manual doesn’t state or address pinion gear shim adjustments other than the initial fit but I’m almost thinking that I need to adjust the pinion gear shim pack and that will take care of the excess clearance in both directions.
The deviation marks are long gone so I figured I just start at the point it came apart.
Looking for some advice.
