So I was wondering if anyone new the settings for the pilot screws on a 1993 Yamaha 70 2 stroke and if these were not at the right settings how would this effect performance thanks
70hp 2 stroke pilot screw settings
Originally posted by rodbolt17 View Postthat 70 uses a pilot fuel jet and a fixed pilot air orifice.
the A/F ratio is not adjustable just the amount of the fixed a/f that is allowed into the intake is.
1 1/4 turns is the book spec, I find 1.5 usually works better.
Originally posted by Dusky 13 View PostIs that tightening all the way down then backing off 1 1/4?
As rod bolt noted, it might idle better at one and a half turns out from being lightly seated. Or, maybe in just a bit more in than normal. All motors and carbs are not always the same.
ÂÂÂÂ
