I tried for hours to get that little piece of pipe out. The corrosion has a death grip on it. It's just not going to happen. So much for shortcuts.
So a few questions about removing the midsection/upper case -
Will the upper case need to be removed from the bracket? If so, does the entire shift rod assembly need to be removed, or just the shift rod? Will the oil pump need to be disassembled, or simply removed?
I've never pulled a powerhead or disassembled a midsection on an outboard before. I'm confident in my abilities, but this is all new. Am I in over my head?
