I recently bought a boat powered by a Yamaha F115 TX. At WOT, I hear a whistling noise. After doing some research, it seems that this whistling noise is caused by a dry driveshaft bearing and can be silenced by greasing the top of the driveshaft. So - I pulled the LU today, and the water cooling pipe snapped-
I can look up into the lower casing and see there were two grommets. One came out with the pipe (as you can see in the picture), and one is still in place. I checked SIM Yamaha, and the part number I come up with for the pipe is 90440-16002-00. I checked that number online, and I'm getting results for 2006 and later Yamahas, which makes me think that this may not be the right part number for a 2003 F115.
Can anyone help me confirm that this is the right part number? Also - does this tube extend all the way up to the power head
