1991 yamaha txrp 200hp. The center hydraulic cilynder on the tilt and trim unit needs an o-ring that rests in the id or inside of the cap . this o ring prevents the hydraulic fluid from bypassing and exiting under dust seal the rod slides in and out of . This center hydraulic cilynder also needs a dust seal on the exterior side of the cap . Any idea how I can attain theses two items. The outter two cilynder parts are readly available but the center one being a diffrent diameter are not. Thank you,
Steve.
Steve.
