F150BET tilt trim stopped working. Relay is clicking, fuses good. Give tilt/trim motor a couple of light taps tilt/trim motor works (very slowly) - assuming brushes are worn.
This tilt/trim is the newer (?) model with the metal reservoir - from the parts diagram
2006 and Later F150XA Yamaha Outboard POWER TRIM TILT ASSY 2 Diagram and Parts
I can only find one brush listed is the second brush part # 63P-82181-10-00
Thanks for advice.
Andrew
Thanks for advice.
Andrew
