Hey guys. I have a bit of a problem. After about 15 minutes of running the primer bubble collapses on itself and the engine begins to run rough and stall. If i wait a few minutes the primer bubble expands and the engine runs fine. Does anyone know the problem or a possible solution. Thanks
130 2 stroke motor problem
Also check your fuel hose, some fuel hoses are dual walled and the inner can separate from the outer.
here is a good soundtrack that i listen to in the workshop continuous it may help
https://www.youtube.com/watch?v=NjTOZ29p-fULast edited by greasyshaft; 10-19-2014, 06:30 AM.
