130 2 stroke motor problem
  • 130 2 stroke motor problem
    Hey guys. I have a bit of a problem. After about 15 minutes of running the primer bubble collapses on itself and the engine begins to run rough and stall. If i wait a few minutes the primer bubble expands and the engine runs fine. Does anyone know the problem or a possible solution. Thanks
    may be gas tank vent clogged
      restriction in fuel line or tank pick up or tank vent
      Some built in tanks have check valves that cause problems
        130hp 2stroke engine problem
        yea check that seemed ok can not work it out maybe fuel pump? . thank you for the reply.
          You either have a restriction before the primer bulb or a venting issue.
          The primer bulb goes flat with negative fuel pressure.
            Not the fuel pump.
            If the primer bulb is going flat there is a restriction between it and the fuel tank.
            The fuel pump is pumping fuel faster than the supply can provide.
              130 2stroke motor problem
              thanks for the info will change the tank see if that will fix problem. thanks guys.
                Also check your fuel hose, some fuel hoses are dual walled and the inner can separate from the outer.
                here is a good soundtrack that i listen to in the workshop continuous it may help
                https://www.youtube.com/watch?v=NjTOZ29p-fU
