water pump 225 four stroke
  • water pump 225 four stroke
    I see nothing in the manual or service schedule about water pump servicing or changing. I looks like a fairly big job. Should it be serviced or changed and if so how often.
    Maybe I'm just overly concerned its my first outboard. My I/O
    needs a new impeller every other year.
    Any info would be helpful.
    http://www.yamahaoutboardparts.com/f...s-th11558.html
    If you ask you will receive,
    but a simple look at the stickies at top of main page would have given you the info
      Go to:Yamaha Outboard Maintenance Tips for videos/explanations for many procedures including water pump replacement.....it's not a very difficult job for an average mechanic....just study the videos/tutorials, take your time and in a couple of hours you should be good to go....
        Water Pump Replacement
          It's an easy and fun job to DIY.
          Don't make the rookie mistake that I did - ensure that the shifter socket engages the shift pin when you re-mount the leg!
          And change your drive shaft bushing while you're at it!
          SIM (link above) has a good tutorial and sells all the parts you'll need to do the job.
            job takes about 1.5 hours, 2 if its Monday.
            anymore than 2.5 and your milking it.
            while you have the wear plate off, remove the slinger and inspect the drive shaft seal garter spring.
              Thanks every one very helpfull
              good advice and great links!
