I have a weird tilt problem. Can tilt full up or down once, then don't have any tilt. Let it sit overnight and I have tilt for a minute or so and it stops again. Relays and relay contacts check good. I see there is an internal circuit breaker in the tilt motor. Can it behave that way? The way it looks in the diagram I'd think it would be a fusable link.
The tilt motor resistance (blue to green wires) varies from around 250-400 ohms which seems odd. I can't find a specification anywhere but since both brushes are in contact with the commutator I'd think it should be a pretty low value.
Any suggestions?
Bob
Cape Coral, FL
Any suggestions?
Bob
Cape Coral, FL
