P200TLRP Idle speed
  • P200TLRP Idle speed
    Hi Have a p200tlrp. in neutral idles at around 500 rpm. but pull It into gear and the revs drop to around 400 rpm. what should they be? I have noticed that it has a really small vibration in gear at 400 rpm. any help or info would be really appreciated
    Idle may be a bit low...should be in the 750RPM range....
        IN gear?? or in neutral? I did notice after running the engine on some good fuel and oil for a while and running a good engine flush that the revs have dropped even further. Hence I was chasing the idle Speed.. Cheers Jay
