Gurus I have a 1990 225 2 stroke carb model number 225ETLD. I have questioned the oil injection system since I got it (from a donor blown up motor) and have been pre-mixing on a rebuilt motor for break in and also because I questioned it anyways.
I have ran the motor for a number of hours and I know that the onboard oil tank is not drawing down. I bought a new oil pump and was replacing it today when I decided to experiment with the old one. Observations;
1. With the old one on and all 6 outlet lines pulled I rotated the pump manually. Some oil would come out every now and again. Cannot say for certain if it came out all 6. The pump intake was still connected to the oil tank. I bled it as well. A few air bubbles came out but nothing major. I noticed that I had to spin the pump about 4 times before anything would shoot out. This was mostly repeatable about every 4 revolutions or so.
2. I blew into about 3 of the outlet lines that go up to the intake. I expected that they would blow free but none did. It was like blowing into a closed container.
My question is what I saw in item 1 with having to spin the pump so many times is this normal? For item 2 is this normal as well in that there is a check valve or something else putting back pressure on the lines? I would have suspected it was just atmospheric pressure as the oil intake is just behind the butterflies on the carbs.
Just want to know if I am on the right track or not changing the oil pump.
