Just to double check, you did both pos and neg, right?
OK, well it was at least worth a shot. Eliminating variables is still a good thing. Maybe you've already done this, but just in case...With the hood off, take a look at the wires coming into the engine from the rigging tube - looking for anything that is "stretching" as the engine turns. Just go through everything with a fine tooth comb, looking closely at the wires - both where they go into the there connector and where the attach.
Can you post a pic of the rigging tube? Just wondering if it's too tight.
What other wires go from the boat to the engine via the rigging tube? They could be possible culprits.
