I recently purchased a 2004 18.5 Center Console with a 2003 F115 Yammy. Lots of dirt bikes in my past have convinced me of the benefits of owning Japanese internal combustion engines and equipment. But this is my first 4 stroke outboard, and, even after owning and operating boats for 60 years i have a lot to learn.
First, do 2 stroke 115s have carbs? Mine has fuel injection and is a four stroke.
Second, on other forums I have read that older 115s like mine are pretty bullet proof but you do get the occasional fuel related problems. My Yammy has 408 hours and although I don't know it's history (it was a brokered boat) I don't think it saw a lot of use lately. When winterizing I found that the oil filter was last replaced in 2016 and the spin-on and internal fuel filters were replaced a year ago.
Replacing the VST filter looked to be a bit of a project, so I didn't want to tackle it in the cooler weather here in Massachusetts. I'm thinking I'll do it in the spring.
When we went for the sea trial and another "Damn, we just got a new boat and I don't care if it's 42 degrees out" ride, the boat performed well except for sustained open throttle operation. We ran max RPMs for maybe 3 or 4 minutes and it started breaking up. Lower RPMs and it was OK.
I read that issues like this are usually caused by lack of fuel. I'm hoping that when I get a chance to run it more next spring it will sort itself out. But, if not, should I start by replacing the VST filter? Then clean the injectors? Yuck.
Oh well, thoughts on this issue?
thanks,
Peter
thanks,
Peter
