2000 OX66 150hp fuel injection. Seem like I'm having a fuel leak. Do these motor got a fuel pressure relieve after you stop the motor. I was cleaning the inside my motor with the key on position to hear the high pressure fuel pump build up pressure . I fire up the motor for a few second then shut it down. I happen to look at the fuel rail that connected to the VSt fuel hole .I notice small amount of fuel dripping down from the bottom fuel rail where fuel hole connected out from the vst. Is this leak common?
Fuel Leak ?
Look at the Yamaha parts catalog for the part that you need to repair.
Start here
2000 SX150TXRY Yamaha Outboard FUEL INJECTION NOZZLE Diagram and Parts
A photo of the leaking part will be work a million words.
Â
